Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Greens instead of blacks. Temporary fixable, but not permanently
Hello,
My mum has unibody macbook pro 2009 17" (3.06)
It has an annoying problem - it displays greens instead black, and it can be fixed temporarily by pushing the middle of palmrest over the keyboard (there is a radiator)
I suppose that it is caused by faulty flex cable. Did anyone have similar problem?
Thanks for help in advance
Update (11/11/2017)
I replaced thermal grease. And happened something after reasembling the computer. I noticed that screen goes green when i push the bottom of the laptop around place shown on the photo
2 Comments
External monitor works properly
by
Then your LVDS cable is damaged or the LCD its self.
by
Add a comment
Chosen Solution
SOLVED
I put silicone or rubber port covers inside.
Back cover was causing problems. Now it is properly isolated and doesn't touch the mainboard. Everything is fine now!
Add a comment
Most Helpful Answer
To try to determine if this a cable, battery or GPU issue, plug it into an external monitor and see if the same thing is occurring there.
Score 1
2 Comments:
External monitor works really well
by
Also check to see if your battery is swollen.
by
Add a comment
Add your answer
Maciek Welk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 63
