Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Questions View all
Home button is not clicking anymore
Suddenly the home button of my ipad mini is not clicking anymore,
it kinda works but there is no movement; it seems like it's stuck
in the "pressed" position.
Is anyone familiar with this issue?
Add a comment
1 Answer
Chosen Solution
It's certainly possible that the actuator mechanism is "stuck". Did this iPad come into contact with any water recently? You could try to put a tiny amount of >90% IPA on the Home Button. Let me stress "TINY" because if you put too much, the IPA could seep into the LCD and cause some damage there. If the actuator won't come unstuck, the device will have to be opened and the switch replaced.
The mini is not the easiest device to work on if this is your first time...
Score 3
Add a comment
Add your answer
dell desmond will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 848
