The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Joycon/procontroller Bluetooth chip/antenna inside switch?
Hi all,
Long story short none of my Joy cons / pro controller work any further away than a few inches from the switch.
I sent the switch in to Nintendo without this issue and a joycon issue, however it came back where nothing will work wireless more an a couple of inches away from the switch joycons or pro. Nintendo wouldn’t repair due to a crack on the power button.
Could someone tell me where this is located within the switch please? As I’m assuming someone opened it and something isn’t connected/missing.
Thanks
4 Comments
Thank you Alex :)
Will give it a go
by
hey, were you able to fix this?
by
I'm having this same issue however my Switch has never been repaired, dropped or damaged before. Did this work out for you?
by
@Will Wunsche Yes I fixed it, upon opening the ZIF connector as listed below had been disconnected.
by
Add a comment
1 Answer
Chosen Solution
Hi!
While I couldn't find a proper picture of the antenna placement on our teardown guide, there is a mention of antennae here at Step 10, perhaps you could tear it down until there and see if you can spot the antenna ZIF connectors.
Score 3
Add a comment
Add your answer
Simon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 2,775
