Repair guides and support for your Sanyo TV.
360 Questions View all
TV went black, just sound!
Have Sanyo model DP19648. Screen is black, sound works. Powers on and off, green(power)light works with tv power button on set and both remotes. Set stays on with sound until powered off. Did the flash light test nothing visible. Channels change on Fios box and audio changes according to the station selected. No functions appear on the set when adjusting volume or changing channels. Removed power board to see if anything was noticeable, no burn/flash marks that I can see. Is there a specific location on the board that I should look into? Is this a common problem? Can a tech/repairman test this board outside of the unit? Is it worth repairing? Can it be done inexpensively or is a refurbished replacement available that wouldn't cost more than a new set?
Submitted pictures, named files just to separate in my computers folder not for any relevance of part numbers etc.
Add a comment
1 Answer
@nuwealth nothing wrong with trying to fix it, or at least checking it out. You do want to go ahead and unplug all your inputs and start checking all of them individually to see if that makes a difference. To start your troubleshooting use this flowchart
It might help if you post some good pictures of your board and wiring with your question. That will allow us to see what you see. Use this guide for that Adding images to an existing question
Add a comment
Add your answer
ARN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 4,762
