iPhone 6s screen replacement help
Display cable bracket. Bottom two screws won't come un done and I even ordered a new kit, still no go. Any tips??
Hello,
This could work but it might not but it's worth a go if you have the gear.
My recommendation is that you take the whole motherboard out with the screen as it's still attached to the board. Then grab some solder and a soldering iron. I have this gear so it would be easy but if you don't then it might not be the best option for you to try. Put the soldering iron onto the screw hole and touch some solder onto the soldering iron tip. The screw hole then should come off. Then do this for the next one. That should get the bracket off and then you would need to put the screw holes back in.
This is of course if your screws are completely not able to come out but first I would try to use different screwdrivers as this is sometimes the case. Try and use a bigger screwdriver if you can. Don't be scared to apply some pressure but not too many. Hope this helped
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
is the screw heads stripped
by daniel
