Model No. A1367 / 8, 16, 32, or 64 GB capacity
should I replace both back & screen
i dropped the ipod on its corner the screen is shattered, i want to replace it but i noticed the metal case at the back of the ipod is slightly indented, will i have to replace both or can i just get away with replaceing the screen???
Score -1
Add a comment
1 Answer
Chosen Solution
I use several metal burnishing tools for working on cases. You can move metal with light pressure and rubbing back and forth from the back side. Here's the concept: http://en.wikipedia.org/wiki/Burnishing_...)
I use smooth bright metal bars of different diameters and a dental tool with just a round metal ball on the end. It helps if you have some junk drawers with old metal parts.
Go here and down to burnishers: http://www.ifixit.com/Answers/Edit/43924
Score 2
2 Comments:
+ The burnishing is great to make decent repairs and to fit the pieces the way they should, but if one has never done it, I don't think the back of the Touch would be a good place to practice :-) I'd get a new back and save the old one to practice than buy a touch of ebay to be fixed and so on...:-)
by
Turkey is right. This procedure needs to be practiced. Put a tin on a tin can with both ends cut off and see if you can work it out.
by
Add a comment
Add your answer
sonni will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 821
