The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 Questions View all
My charging port appears to be broken, charging problem.
The inside part of my charging port on my Nintendo 2DS appears to be bent. It will only charge if I move the charger to very weird angles. Could it be fixed if I unbend it, or do I just need to buy a new motherboard? Thanks, Matt
Add a comment
1 Answer
Chosen Solution
Hi!
You could try to resolder that yourself if the the port only broke loose from the board. You'd need a lot of patience and there is a fairly high risk of damaging other stuff unintentionally.
The best way to solve this is indeed by replacing the motherboard, but you'd loose your data as far as I know, since you can't really backup and restore 3DS software without having both the new and the old console working (you use the old system to upload the data to the new one, but then the old one get reset to factory default settings).
Score 3
Add a comment
Add your answer
Matthew will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 1,039
