Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
How to remove earpiece
I've hunted around for this, but I haven't been able to find it.
I've repaired quite a few iphones so am not a novice. However I've yet to be able to work out how to unclip the actual earpiece from the mid frame.
I can remove the sensor flex assembly, but not the actual earpiece from underneath.
Thanks in advance
Score -1
Add a comment
1 Answer
Chosen Solution
you have to remove it from the backside. remove the ribbon then you can remove the speaker. if not careful, you will damage it. a non issue if you are replacing it. i use a microscope to do it and keep it intact. use a small pick or pointy tool.
Add a comment
Add your answer
Chris Zammett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,440
