Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Looking for MBP Unibody replacement rubber feet.
The rubber feet on the bottom of my 17" Unibody purchased in March 2009 have all separated or peeled off. I have looked through the available ifixit parts as well as elsewhere online and am unable to find replacements. I would really rather not spend $150 on an entire new bottom plate just to replace the rubber feet.
Any ideas?
Ben
Add a comment
Most Helpful Answer
These will probably work fine for you: http://www.welovemacs.com/mbp15rfeet.htm...
For clarification: The Unibody feet have one "pin" (that the wrong word) and a large center. The Retina fest have a small center and one pin. The MacBook Airs have two pins and a small center.
Score 2
Add a comment
it's not for the unibody macbook pros.
it's the rubber feet for older models.
mayer;
Add a comment
Powerbook Medic has replacement feet at http://www.powerbookmedic.com/Macbook-Un.... Note that these are rubber rather than plastic, so your unit won't slide around once they're replaced. (This could be a plus!)
Add a comment
Add your answer
Ben Stineman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 5,924
