Replaced CPU with i7 - now 1 LED blinking
Hi,
Model: iMac "Core i5" 2.7 27-Inch (Mid-2011)
I replaced the i5 CPU with an i7 2600. But on boot I got a blinking single LED on LED1. Reading up that normally means insufficient power.
The main fan would spin cycle up and down.
I put the i5 back in and it boots fine.
Things I'm not sure about:
- I'm assuming the CPU is good, but can't be 100% sure
- I didn't put the RAM back in when I tested the i7, but normally you'd get a long tone.
Anything else I can try?
I'll have another go when I've got more time and double check I've seated all the cable correctly etc...
Big shame if it doesn't work - I was looking forward to the upgrade :-(
Thanks!
1 Comment
Hi i have the same problem with a1419 late 2013 led # 1 blinking, so i bought i new power supply. Installed and i get the same blinking Led #1 so sad.
by Samuel Mauricio Garcia
