Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
Keyboard randomly malfunctions; turning off and back on temporary fix
The keyboard works great when it works, but suddenly for no apparent reason, it stops responding and/or wrong characters appear. Turning it off and then back on fixes the problem for awhile, but it happens often, sometimes daily. Bluetooth connection and battery level is fine when it happens. Thoughts?
Add a comment
1 Answer
Chosen Solution
Could be one of several possible issues.There were firmware updates that may not have been done. Even though the batteries are showing OK< I would change them out for new ones to remove that possibility. You did not say what you are connecting to nor what OS X you are using. You may need to do an update. Your Bluetooth board or connections may be going bad.
Score 1
Add a comment
Add your answer
Mindy Hughes will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 10
All Time: 189
