The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
car won't start, door locks , windows won't work, brand new battery
Had a new battery installed when my car died, still will not work. Mechanic says that a module has shorted out, but what one? windows, locks shifter will not engage at all. Headlights and dash lights work, Starter is good.
When trying to start just clicks.
1 Comment
Have you checked the fuses?
by
Add a comment
1 Answer
Most Helpful Answer
With the information you've given, unfortunately, it'd be hard to pinpoint a specific component causing the issue. Newer cars use complex computers/modules that can and will disable functions if certain signals are missing or parameters aren't met. The first thing that pops into my head is the "immobilizer system". Often times after a battery is replaced, the security system will disable the vehicle until the system is reset. Otherwise, the problem could be one of many different things. Sometimes an expensive diagnostic machine/scanner will be the only way to verify some of these issues. Could you elaborate on what happened when the vehicle died to begin with that prompted the battery replacement?
Score 1
Add a comment
Add your answer
Tammy Gilbert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,224
