1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Questions View all
My device won't power on nor charge
I recently bought a new macbook air and I can't seem to get it to charge nor power on. When I plug in the power adapter the LED does not turn on at all (not even a dim green light). The problem is not from the power adapter as it has been used on another device. I also tried to change the outlets but nothing happened.
I don't know when it was last powered on as it's a second hand device. I have tried all the SMC, PRAM/NVRAM resets and I still got no response.
Does anyone know what the problem might be?
Thanks for the help
Add a comment
1 Answer
Chosen Solution
See if you can get a spontaneous boot. Disconnect the mag-safe & battery. Press and hold the power button for 10 seconds. Reconnect the battery and the mag-safe. You should get a spontaneous reboot.
That failing see if you can get your money back. You got stuck with a money pit.
Score 2
2 Comments:
I'm waiting on the pentalobe screwdriver since I couldn't find any from here. Doubt I'll be able to get my money back unless I try to resell it for parts.
Thanks for responding so quickly
by
Well it's right here: P5 Pentalobe Screwdriver Retina MacBook Pro and Air
The only other driver this baby uses is this one: T5 Torx Screwdriver
by
Add a comment
Add your answer
notanexpert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 78
