Released by Nikon in March 2015. Part of Nikon's Coolpix series.
I get msg 'wait for the camera to finish recording'
when I press the recording mode I get this msg 'Wait for the camera to finish recording'.
I have a 3GB memory space and I have put new batteries.
Also I takes some time to capture the picture when I click to take photos.
Kindly suggest me solution
Score 1
1 Comment:
Hi @umasaty ,
What size memory card have you got inserted?
Have you tried downloading the contents of the card, reformatting it and then trying it with an "empty" card to see if the problem is resolved.
Have you tried a different SD card? (max capacity 32GB, ensure that it is Class 6 or higher)
by
Add a comment
1 Answer
When you record something like a picture of a video, the Camera writes the data into your removable Cards i.e. SD cards, CF cards etc, In cases where the File is large, such as 4K videos for instance, it could take the camera a while to write all the data into a card hence it wont allow another action i.e. taking another photo until all required data has been written to the removable card. If you are simply taking HD videos or normal photos (not 4K videos) and youre still getting this msg then your removable card might be a bottle neck, try changing your removable card to something that supports higher write rate i.e Class 10 SD card = min 10mbps) this should allow your camera to finish writing all required data to the card by the time you are ready to take your next shot.
Add a comment
Add your answer
Uma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,763
