Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
loose touch id/erratic after screen replacement
hi,
i just changed my broken iPhone screen using a third party screen and jkept the same home button everything work but the touched home button is slightly loose with i think is causing the touch id to be erratic as sometime it won't recognise my fingerprint and when i add a fingerprint it is really difficult as sometime it might say "cannot read this fingerprint" or "you moved your finger slightly" etc managed to do it with one finger but sometimes it will unlock the device other time it won't.
personally i think it is the gasket that hold the button in place it might be lacking adhesive but I'm not sure
anybody know how i can get it to sit firm again and if this will correct the problem
thanks
any help will be thoroughly appreciated!
Add a comment
1 Answer
Chosen Solution
I would open up the phone and check if the Home Button gasket is properly securing the home button. If it is loose, then you should change it. You can find one here. While you're in there, also inspect to see if the Home Button and it's flex cable appear damaged in any way.
iPhone 6 and 6 Plus Home Button Gasket Image
Product
$5.99
Score 2
Add a comment
Add your answer
israr7862013 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 3,385
