Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Phone Won't update to iOS 11.0.3
I have not had issues with my phone in the past, nor did I after I updated to ios 11. However when I tried to update to 11.0.3, I keep gettting an error saying that the update cannot be installed. I have retried the update as well as deleting, redownloading, and then retrying both to no avail. How can I fix this?
Thanks!
1 Comment
SAome time air update error causes error due to storage full or battery level low,if you have to update anymore use iTunes or 3u tool to update manually before restore backup important data and restore and update not only update.
by
Add a comment
Most Helpful Answer
It sounds as if your phone storage is full. Try deleting some apps and photos to free up room. Other than that, is there any reason for failure? Try clicking install and leave it alone. Press the button and walk away.
Hope this helps!
Score 2
6 Comments:
I checked and I have over a gigabyte of memory left open. I tried again and it propmtly failed in under a minute. I'm at a bit of a loss here...
by
@jack35 Still try freeing some space. It requires more than you know.
by
The problem I have right now is that 7 out of 16 gigabytes is "System" memory and another gygabyte "Settings". I have 7 gigabytes of stuff I put on the phone but it's spread out through a number of apps I'd rather not delate. What should I do?
by
@jack35, If you have any photos on it move them to your Mac/PC/cloud storage. If you have any videos downloaded delete them. If you notice any apps are taking up more space than they should, consider deleting them. Also, have you restarted it yet? It could be as simple as a force restart. How to Force Restart an iPhone 6
by
Hard reset did the trick. I'm kinda facepalming for not trying the oldest trick in the book first...
by
Show 1 more comment
Add a comment
My iPhone 6S won't update past 11.0.3. when I go to check updates it says that it's up to date
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 7
All Time: 10,305
