Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Taptic engine not working - how to test outside of phone.
I got a client's phone today that is not vibrating. It was previously jailbroken, and had the issue a few months after that. Now after damage, no signs of drops, I'm the "first one" in it. (found some finger prints in the speaker)
I'm not sure if it has a bad lightning assembly, taptic engine or something else. I don't have spare parts to test at the moment. Any idea how to test it outside of circuit? Or any pin outs for it? Ideally I'll have another iPhone 6sp come in to try this one in that phone, but I'm not holding my breath.
Thanks
2 Comments
could you not add voltage to it guessing about 3v
by
I could, but with what current and to what pins? It has a flex cable going to the lightning dock with about 10 pins I think? I don't have it in front of me.
by
Add a comment
Most Helpful Answer
Try to get a dc power supply and take out the Taptic Engine then slowly increase the voltage to it to see if it moves. Or get a multimeter and measure the voltage across the pins on the lightning connector and make it vibrate and see if any voltage comes up.
Score 2
Add a comment
ideally you should get some test parts as trying to test it could be the hard part and still not lead anywhere
Score 1
2 Comments:
Yep, ideally I would. But I am looking for another solution that's why I posted here and why I said I don't have any test parts. Unfortunately I don't see any output on ZXW for its plug as it is on the lightning assembly.
Do you have a working one? An oscilloscope you could test the output frequency and voltage with? That would be super helpful.
by
i dont only iphone 6 and i dont use an oscilloscope, can you not change vibration settings in sound to see if it works
by
Add a comment
I have this problem with my 5S, he must of installed some Taptic tweak. If you press the bower button and volume up and down buttons at the same time you should feel a vibrate. Sadly updating the phone doesn’t fix it, and neither is restoring the phone from a back up.
The Fix. You will have to reset the entire phone and not restore it from a back up.
(Back up info just in case)
1 Comment:
I did a DFU restore from a new firmware I downloaded from Apple. 11.0.3. Phone is like new now, but still no luck on the Taptic problem... I think tomorrow I will recieve the parts, but the person needed their phone back - Maybe I will get my hands on it again in the future.
by
Add a comment
Add your answer
Joseph Hughes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 20
All Time: 4,670
