4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
iPhone 5SE doesnt turn off?
Hello,
I am having in repair one iphone 5SE. The device cant be turned off. First i thought it was the power button flex damaged. ( with the old flex you could turn the device on but cant turn it off- you cant turn the lcd black again/lock the screen). So i ordered 2 power button flexes and both do the same, you can turn the device on(when the screen is black or the phone is turned off) but when the phone is on, you cant turn it off, or lock the screen.
I also tried the assistive touch and when you choose the the lock screen option on assistive touch the screen still reamins on?
I dont know how to solve this issue if the assistive touch doesnt work, it should be a software issue??
Add a comment
1 Answer
Chosen Solution
At this point, the only options left are software or logic board. If data retention is not an issue, you could try restoring the device to factory conditions. If that doesn't solve the problem, then there is likely a logic board issue and the power line will have to be looked at in more detail.
Score 2
Add a comment
Add your answer
infoservis112 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 104
