The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 Questions View all
Samsung Logo appears and goes Black Screen and LED stays solid blue
This unit has been getting to me.
The initial issue was a random OS installed was causing some issues with Samsung features. He also noted that the phone would restart itself time by time for no reason.
Thinking it was no biggie, I flashed the OS with the stock OS from Samsung Switch.
I was able to back it up, restore the information, all good!
Turned it off and left it charging so his notification would not constantly ring.
Came back to turn it on. The Samsung S7 Logo appears and then black screen and solid LED Blue.
None of the manual commands work - - Power + Vol Down + Up, etc. I eventually left it alone to die and came back plugged it into the charger, works. Try to turn it on, same issue.
Is this the board causing the issue or a possible corrupted OS?
Add a comment
1 Answer
Chosen Solution
Board needed to be replace, unsure what exactly happened to it. Replacement did the work.
Score 1
2 Comments:
Does replacing the board result in the loss of all the phone data?
by
Yes, as the memory is on a memory chip the logic board on every phone.
by
Add a comment
Add your answer
Juax will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 5
All Time: 781
