4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Water damaged problem can soak with alcohol or not?
just wonder my phone is damaged due drop in a pool,if i wanna use alcohol to clean the motherboard,how long its take to soak in alcohol?
Score 1
Add a comment
Chosen Solution
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while (5-10 minutes).
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Score 3
Add a comment
I have watched a few videos and about to try to see if I can resurrect an iPhone 6 that was dropped in water nearly 3 years ago…the phones in mint condition lol other than the fact it doesn't work
I shall report back with the results…Kris SK
Add a comment
I don't recommend you to use alcohol I would recommend you to use rice.
Score -1
1 Comment:
Rice actually promotes evaporation and does not get rid of the deposits nor does it stop the corrosion..rice is great if your going to claim insurance but if your doing a real repair to a 500 dollar plus phone and you don’t have either; the suggested guide is proper to follow.
by
Add a comment
Add your answer
Kennykua will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 8,078
