Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
"are you sure you want to shutdown your computer?" random popups
I have a mid 2010 MacBook Pro. when inactive for 5 seconds it pops up a message saying "are you sure you want to shutdown your computer now? It does this by itself like clockwork and if I don't press cancel immediately it shuts down. I have jammed one of the keys down so its not inactive and this has stopped the pop ups but that is obviously not the right thing to do, please help!
4 Comments
Did you have a liquid spill into the keyboard or trackpad at some point?
by
Hi Dan thanks for the assistance, not me personally but I did buy it second hand so there is that possibility, however I haven't noticed any problems with the keyboard or trackpad they both seem to work perfectly, how would I be able to tell if there has been a liquid spill?
by
[image|1215277]
there is some discolouration there
by
I don't think I posted that image lol
by
Add a comment
Chosen Solution
Do you have access to an external USB keyboard & mouse?
If you do lets open up the system and do an inspection to see how it looks. Post pictures of anything that looks suspect. Dust it out using a soft brush and can'ed air.
What we'll want to do here is disconnect the keyboard and trackpad ribbon connections then using the USB keyboard & mouse see if you still encounter the problem. I'll warn you the system will ramp up the fans as they are going into Safe mode as the sensor or the trackpad will be disconnected when you pull its connection so don't let that bother you. We don't want to let it stay this way too long either as you don't want to over stress the fans.
Follow this IFIXIT guide: MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement Follow the first three steps, then jump down to Step 11 pulling the trackpad connection (3rd image) and follow Step 12. Use care as you don't want to damage the connector or the ribbon cable. To ease it back in I use a small piece of electricians black tape folded over to make a pull stuck on the ribbon.
Is the system still wanting to shut down? If not you'll need a new keyboard. If is still wants to shutdown we'll need to look into the battery & temperature sensors within the system.
Score 2
3 Comments:
Thanks Dan, I will have to get myself a set of tools first but then I will definitely do that. Someone told me that it might just need a good clean, is that possible?
And do you think it is safe to continue using it as I am now - with the f7 key jammed down to stop pop ups?
by
I would hold off using the system until we can isolate the fault. Lets say its something other than a bad keyboard. You could end up making things worse.
As for cleaning it, older systems do need a cleaning as the cooling systems do get messed up with stuff interfering with the fans and cooling fins in the heatsink. As to being your issue not sure.
So yes its something I do all of the time. I've been called Suzy homemaker a few times ;-} As I'm constantly cleaning.
by
I opened it up and everything looks fairly normal ( I guess) except for this...
by
Add a comment
It's the keyboard cable. I have a 2012 15" MacBook Pro, it started after I had accidently pulled the wrong cable (thinking it was the battery connector). I realized this, went back, cleaned the cable with alcohol, repositioned it, and it works fine now with NO popups of "Are you sure you want to shut down your computer".
Add a comment
Add your answer
dean will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 5,535
