Repair information for the Gaggia Classic Espresso Machine.
20 Questions View all
Not enough water pressure to force through the pod
Unit comes on, when ready to force water through the pod, the unit sounds like it goes to half power. Made sure pod isn’t too tightly packed. Regularly descale the machine, hoses are clear, unit is primed, just very little water pressure. What is the issue?
Score 1
1 Comment
Me too! Wish I had a guy near by to fix this.
by
Add a comment
Chosen Solution
Why don't we see if this solves your problem
https://m.youtube.com/watch?v=Ghti27dMZb...
Score 3
2 Comments:
@oldturkey03 thanks. I had good teachers!
by
Add a comment
Most Helpful Answer
@shammond86 you definitely want to check all parts for obstructions caused by debris or buildup. If all that looks good and is clean you need to consider bad hoses or a pumps issue.
shows a typical water circuit for the Gaggia
Score 4
Add a comment
Add your answer
Susan will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 15
All Time: 6,040
