Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
237 Questions View all
Why is my charging port, headphone port and home button not working?
I accidentally dropped my phone in water for literally one second then I took it out dried it and my it in rice. about 2 hours later I went to check on it and it was working fine everything working but then the home button, power button, charging port and headphone port stop working. I put it back in rice for another hour and then my charging port and power button and home buttons fingerprint scanner started to work but shortly after the charging port stopped working. what should I do now?
Add a comment
Chosen Solution
@maxtab take it out of the rice. Rice is great food but it is not a tool. It does not work. It does not stop corrosion nor will it fix your phone. Rice as a desiccant is a myth that has to disappear. This site has long advocated for that.
The very first thing you want to do is to not try to restart/sync or charge the phone. This may further damage your phone. Remove the battery.The next thing to do is to clean it. Disassemble your phone using these guides.. You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning the board properly. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G, all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred missing or broken missing. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. It does not matter how long your device was exposed to the water. What matters is where it was exposed and which part got damaged. Once all this is done, reassemble your phone and reevaluate. You can only determine what has failed and what does not work, after you cleaned the phone properly.
Score 1
Add a comment
Most Helpful Answer
I'd suggest checking to make sure there's no rice stuck in the phone first. After that, this thread might have some helpful hints: How do I recover a galaxy s6 from water damage?.
Good luck!
Score 1
Add a comment
91% alcohol does wonders for evaporating and cleaning water damage.
Score 1
1 Comment:
I did forget to mention to make sure that no alcohol seeps into the screen/lcd area as it will cause discoloration. Sharp pointed tweezers can dig a lot of crud out of charging ports as well. =)
by
Add a comment
thanks to everyone i used a mix of what you all suggested and it worked. thankyou
Add a comment
This is water damage. You'd better send it to an experienced repair shop to clean it.
Score -1
Add a comment
Add your answer
Max tabor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,855
