Why is the secondary monitor turning on and off randomly
I have installed an external monitor (samaung) connected to on my laptop (asus gl552). I am using a HDMI cable for connection. Since the laptop does not have a vga port, I have connected a HDMI to VGA connector on the laptop end and inserted the cable in HDMI port of the laptop..
I have switched off the laptop display and adjusted the screen resolution on the samsung external monitor to 1920 x 1080 and adjusted colors for the Windows 10 and brightness and contrast from the monitor.
The problem is the monitor turns of blank intermittently for 1-2 seconds and turns on again at random interval. What could be the reason for this and how to get rid of this problem?
Please I need help. Again how can I configure the Nvidia card to be used by the external monitor not the in-built intel grapghics 530
Thanks in advance.
Note: The video I inserted is one I found on the net. but That is exactly how mine is behaving. Instead I quickly uploaded it for you to see.
Add a comment
1 Answer
Have you checked your display drivers, and mboard drivers. Physical connections would be a good to check as well. You can also try changing the refresh rate.
Add a comment
Add your answer
Emmanuel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,244
