A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
What's wrong with my HDMI port?
We've had the PS4 for just over 2 years and it's always worked fine, but in the last month sometimes when switched on it just said 'no signal' on the tv but would work eventually. Now it is only showing 'no signal'. I've tried using different HDMI cables and even plugging it into another TV, none of which has worked. The light goes to white and it's possible to turn the PS4 off using the controller from memory so the only problem is with the display. There is no obvious damage to the HDMI port visible. I just want to know, should I have the HDMI port replaced?
Score 2
2 Comments
i have the same problem
by
I have the same exact problem anyone get an answer that helped them
by
Add a comment
Chosen Solution
There's no way to know for sure without being able to see it and test it. It sounds like you done all the basic troubleshooting so at this point it would probably be time to have an expert look at it. Usually, you can see when a port is faulty but sometimes it's very hard to tell just by look at it on the outside. If the HDMI port is indeed good then it's likely that the HDMI encoder chip on the motherboard is faulty.
Hope this helps.
Score 2
Add a comment
Most Helpful Answer
This article has many suggestions to try. Basically: check the port, check the cable, check the software.
Good luck!
Score 2
Add a comment
@l1031 there are multiple questions with HDMI concerns on Answers. Check some like My hdmi port is broken and needs repair or check the user profile for the resident expert @tronicsfix on here and see what he thinks.
Score 2
Add a comment
Add your answer
Lucy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 8,471
