Broken antenna port, can it be fixed?
So I replaced the charge port, the glass back (which cracked when being opened), and the charging port but in the process of putting everything back together again for the 3rd time. I broke the antenna cable port when snapping them off the motherboard logic board. The antenna cables are fine but the port that the cables snap on to are broken. Does anyone know how to fix it or if I replace the whole part, will I still have my text messages and stuff? Tried to show a picture of what I'm talking about but it won't upload on here.
Score 1
2 Comments
Rachel is on fire... You should be able to fix this guy, just be careful soldering equipment can get expensive real fast.
by
@anthonyj I do my best. :-)
by
Add a comment
1 Answer
Most Helpful Answer
Here's someone with a similar problem: Broken antenna connection on logic board, how to fix?
From what I've seen, the connectors at least look standardized.
Here's someone with the same problem, but no answer: https://androidforums.com/threads/broken...
This link has helpful comments, albeit for another device: https://forum.xda-developers.com/zenfone...
It looks like you've got some soldering coming your way.
Good luck!
Edit: As far as your old information goes, if you do get a new motherboard: being that just the antenna isn't working, there ought to be a way to salvage the data. I'd actually back it up before you try the repair described in the third link.
Score 1
Add a comment
Add your answer
shanonsmitt16 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 2,323
