Repair guides and support for Panasonic's Viera line of televisions.
417 Questions View all
Panasonic Viera blinking 10 times and do not turn on.
I have a little bit old Panasonic 40" Viera plasma tv. One day to other i can't turn on. Switch on TV, led blinking green fast and started blinkin 10 times red. First switch on get a popping sound whitout smoke. I want to fix if it can be. Help somebody or ask a tip, Thank you!
3 Comments
krisztianszollosi what is the exact model number of your TV?
by
I would like to ask 50” panasonic plasma tv when the suiz blinks green for a moment and truns a red clips continouosly until it is switcherd off,can you help me
by
TBU914 is our model. Same issue 40”
by
Add a comment
1 Answer
Most Helpful Answer
krisztianszollosi if any of the SUB or MAIN voltages that are highlighted on the DG Board is missing, the unit goes into shutdown. The power LED blinks ten times.
If any of the voltages created on the PA Board is excessive or shorted, the unit goes into shut-down. The power LED blinks ten times.
You do want to start off with simply trying to reset this set
1) Unplug everything that is connected to the TV including the power cord (HDMI/ RCA/ Coax etc)
2) Press and hold the power button on the TV for no less than 10 seconds
3) Connect only the power cord.
4) Turn the TV on.
5) Plug in all other cables as needed.
Score 1
4 Comments:
I try your steps, but do not work. A read a lot of thinks this problem, i think it need to change a-board.
My tv type: TH-D42PF72E
Serial: fs-73504 15 r
by
What is the cost
by
I've done just that and it still doesn't come on and still blinks 10 times
by
@warriorup what exact model is your TV?
by
Add a comment
Add your answer
krisztianszollosi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 21,559
