Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
My MacBook Pro screen isnt working.
My MacBook Pro retina 13" screen isnt working. When I turn the mb on the screen gets illuminated but keeps black screen. Sometimes (usually when I plugged out the HDMI cable) the image comes back and I can see my desktop with all the colours but it blinks and finally fade to white like its burning.
Also I can use the mb with an external display via hdmi and works as usual with my normal desktop.
I've tried the ram/pram keys combination and the SMC too and nothing works.
What could be the problem? Is it expensive to replace/fix it?
Update (10/03/2017)
MacBook Pro 13" 2.4 GHz i5" (Late 2013)
So I should check first if the display cable between the LCD and the bottom base its okay. If not I should be prepared to change the whole LCD panel right?
I'm forever grateful for the help. Woz bless you.
Update (10/06/2017)
6 Comments
Did you get your system wet at some point? I suspect you have corrosion on the display connector internally.
by
I dont remember ever having spill liquid in my mb.
I travel a lot and it did suffer from a couple of knocks but nothing important.
Here's a video of the malfunction of the MacBook.
https://youtu.be/hhCfdLKdg6A
As you see the image comes and goes with normal colours but frozen.
The brigthness button works if it says something.
Also when I plug it to an external device it works as usual.
Could it be a problem of the LCD cable?
I dont think its the card video as it seems to provide good images to the MB sometimes and normal to an external.
Sorry for the long response but Im thinking of fixing it by myself as the repair service would probably charged me 500-600.
by
Okay this is hard to believe..
I went to pick up the tool kit with my motorcycle. I left my macbook in the back pack of the motorcycle which I thought It was a little reckless cause it could get a little bumped while driving.
So I came home prepared to open the guts of my macbook, I first open my macbook and WORKS NORMALLY! the screen is working perfect. I think it could be the bumping in the motor what make it works cause 5 minutos before it wasnt working, and that could moved the lcd cable to make it works.
Do you still recomend me to open it up to see how's the cable looking?
Thanks anyway!
by
Ramon - Thats good! So it appears to be a loose connection then. Yes, you'll need to pop the bottom off to inspect things as I described below and reseat the connector.
by
how can I post images? I think the cable has been a pushed by the lower case. what do you recommend? should I not put the screws around this area to prevent this pushing?
by
Show 1 more comment
Add a comment
Chosen Solution
At this point, I think you need to pop the bottom cover off to make sure the display connector is properly seated and not damaged.
As you believe your system didn't get wet the issue will likely be within the display its self.
Within the display is a set of circuits which demux the signal to something it can use to drive the LCD. We call these chips drivers. The video leads me to believe these are damaged and/or the connection to them. If that is the case you'll need to replace the display assembly
As we don't know your exact model I can't point you to the needed guide or part. Plug in your systems serial number here: EveryMac - Lookup then post the systems URL here for us to see.
Update (10/04/2017)
Here's the IFIXIT guide you'll need to follow: MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement. For now, follow the Steps to Step6 and then jump to Step11 which is the display connector. See if you see any discoloration or if the bail wire is seated across the connector. Carefully disconnect the cable it needs to slide out along the surface of the logic board don't pull up! Until its clear of the connection inspect it as well. If you want to take a picture or two for us to see if you see something.
Carefully reseat the cable and reconnect the battery is it any better? If not I think it's clear you need a new display assembly.
Update (04/28/2018)
Well, you've got corrosion damage and you may have a few damaged SMD components as well!
Score 2
1 Comment:
Im waiting to receive the tool kit to get on with it. I'll keep you updated.
Thanks again.
by
Add a comment
It could be a problem either with the display outputs on your logic board or it could be a software issue. Did you try to restore an earlier time machine backup? If you don't have time machine, try a fresh install of MacOS. As others suggested It could be the result of liquid damage on the logic board, but you mentioned it only suffered some bumps and drops. Have you opened the bottom of the computer to see if there are any loose connections?
Add a comment
for those experiencing this issue, but have not achieved resolution:
i just took in a 2012 MacBook pro retina 13 which had no display. after trying all of the suggestions, i ended up with a working backlight but no LCD.
the solution was to disassemble the laptop and remove the LCD, then remove the clutch cover from the LCD. here i disconnected and reseated all connectors, and partially reassembled the laptop to test.
ALL SYSTEMS GO.
I suspect this computer took a fall also
Add a comment
somtimes i have this problem. I just close the laptop and open it after 30 seconds then it work.
Hope it can help
Score -1
Add a comment
Add your answer
Ramon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 12,585
