Battery has power but no electrical components respond
Battery has power but no electrical comps responsive. Has new ignition switch and battery. Engine turns over when I jump across solenoid with wrench.
If you have to bypass the solenoid then odds are you need a new solenoid . If the electrical components are wired through the solenoid then nothing will work if the solenoid is fried . Replace the solenoid . Hope this helps
My hour meter won't even come on. Battery is good but no electricity going to anything
Mine is doing the same thing. What did you find?
@kerrycollins check your seat switch (11)for continuity when pressure is applied. Check your circuit breaker (24) to make sure it is engaged.
There is a 20amp fuse across from the battery check that I’ve had the same symptoms turns out that’s what it was.
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 158
All Time: 1,943
