Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Questions View all
SOS 9 Beeps (3 short, 3 longer, 3 short)
During the installation of High Sierra, after a restart my iMac now gives a SOS signal at startup.
I tried the reset of NVRAM and PRAM and other relative keyboard combinations at startup without result.
I tried all 4 RAM modules one by one.
Do I need to replace a battery?
Do I need to restore firmware?
I hope that someone can help me
Kind regards,
Kris
1 Comment
Replace battery!
by
Add a comment
1 Answer
Chosen Solution
Sadly your systems firmware is corrupted! You'll need to create a restoration CD following this Apple T/N: About the Firmware Restoration CD (Intel-based Macs).
Update (09/29/2017)
Sorry Kristian I aimed you to a dead end ;-{
I forgot the 2010 model is one that Apple doesn't have a Firmware restore CD available. Give Apple a call or visit an Apple Store to see what they say. Explain you were doing an OS upgrade from ??? to High Sierra.
Update (10/06/2017)
Your system has a BIOS (EFI) which has firmware on it. During the OS update it is often updated as well. During that process it likely got corrupted. The reason your system is beeping is the check sum of the firmware is wrong. Its designed to do this when its bad.
If Apple won't help you you'll need to either replace the logic board or find someone who can replace the BIOS chip on the logic board. Here is the location of the chip on the logic board:
Here's one source for the chip. You'll need to give them your systems S/N which should be on the bottom of the foot: BIOS EFI firmware chip: A1312 Apple iMac 27" Logic board: 820-2828-A
Score 2
21 Comments:
Three long tones, three short tones, three long tones: EFI ROM corruption is detected, and your Mac is in EFI ROM recovery mode. Newer computers automatically recover from a corrupted ROM; when this occurs, a progress bar appears on the screen during ROM recovery mode. Don't disturb your Mac while the ROM recovery takes place. When recovery is complete, your Mac restarts.
https://support.apple.com/en-us/HT202768
by
Hi Dan
Thank you for the advice.
I am going to try it!
Can you please help me with the correct Restoration CD image download link for my iMac?
iMac11,3 (27-inch, medio 2010)
by
Hi mayer
Three long tones, three short tones, three long tones is not a SOS signal.
The 9 beeps I hear are, (3 short, 3 longer, 3 short)
by
I would like to try the firmware restoration CD but I can not find it !?
by
Don't fell bad!
Others aren't even using the correct firmware versions either! Study Finds Significant Number of Macs Running Out-of-Date Firmware Susceptible to Critical Exploits.
I'm sure Apple will start a campaign to address this and maybe offer a better means to maintain older systems.
by
Show 16 more comments
Add a comment
Add your answer
Kristian Schiffauer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 7,452
