Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3140 Questions View all
Water Damaged phone, already charged. Is it still possible to fix?
I was listening music in the pool and I touched my phone to change songs, then my screen got damaged there. I also poured loads of bubbles Into a Jacuzzi just cause I was playing around. I did not dry my phone and suddenly the sound stops working! I lost battery and harged my phone but I am leaving it in rice (just like you guys recommend) and hoping to fix it like that, but today someone removed it and put it on charge, I quickly removed it when I woke up and put it in rice again. is it still possible to fix it (in house)
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Abdullah Obeidat "I am leaving it in rice (just like you guys recommend)" definitely not. Nobody on this site recommends rice! We absolutely despise it! There is no room for rice in repair. Rice is great food but not a tool. Take it out of the rice. IT DOES NOT WORK
What we do recommend is that you no longer try to turn your phone on, try to sync it or otherwise use it. That can make a bad situation worse.
The very first thing I would do is to disassemble it by following this guide. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Use a soft brush 90%+isopropyl alcohol and clean it very, very thoroughly. You must remove all the EMI shields from the logic board.For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. The best cleaning would of course be through an ultrasonic bath. so if you can use that. After you have done all this, reassemble your phone and only then can you perform a proper troubleshooting. Keep in mind that water damage is the hardest to troubleshoot and to repair.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty: Difficult1 - 2 часы
Score 2
Comments:
For some reason the rice actually worked, it took 2 weeks to recover, but still useful and that was my last option but still thank you for answering. i know that it works
by
Add a comment
Add your answer
Abdullah Obeidat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 38
