Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
'Searching/No Service' after replacing lightning connector flex/cable
Hi there everyone!
So, I'm having some troubles with this iPhone 6 Plus..
I bought the phone with a broken screen. Tested it, everything was working properly - including the screen - and there were no other problems, except a not working lower mic (Voice Recorder, WhatsApp voice messages, etc - no sound recorded). Therefore, and with the screen, I also bought a Lightning Connector and Headphone Jack Cable Replacement. Did it all according to the Guide available here, and it all went smoothly - at least I thought so. When I tried to test it, couldn't get any signal. Sometimes it is 'Searching' for a while, but sooner or later, 'No Service'. Reset network settings, done; reset all settings, done. Can't get it to work.
What could I have done wrong in the proccess? Any ideas?
Thank you in advance!
Cheers,
Júlio
Add a comment
1 Answer
Chosen Solution
Was the phone picking up the GSM signal before you opened it up and changed the Dock?
I would go through the guide again and double check my work. Focus on the antenna cable on step S4 and the variety of screws in Step 32. I would also do a very thorough visual inspection of the replacement Dock flex as it is not uncommon to have defective replacement small parts. Look for a damaged flex or missing or damaged components on the flex.
Finally, I would re-install the original flex to see f the signal works again. If it does, then you clearly have a bad replacement flex.
Score 2
2 Comments:
Minho,
Thanks for the fast repply!
Yes, it had full bars before my 'intervention'. I'll do that - fully repeat the guide to see if I didn't miss nothing, but I'm very thorough with this kind of things, including the screws and their place. The worst part is that I was so.. confident, that the old part went directly to the garbage. Stupid, I know.
To be safe, I'll order another one just in case. Will only be able to do it tomorrow. I'll say something when done!
Thanks!!
by
Haha! Yeah, I never throw stuff out :>).
by
Add a comment
Add your answer
coquenao will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,061
