4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Two of the microphones act strange after screen replacement
Hello, so the deal is:
Someone i know got their screen replaced by a private person. Screen works fine, but front facing mic dosnt work. I thought he had damaged the mic, so i tried a new one. But without any luck. It still wont catch the sound, it just makes this pretty blurry noise. I have checked that the dust mesh is clean and open. So can this be any motherboard related?
The other thing is, when i do calls, this main call mic (The one on the dock) also wont work. It works the first second, before it just takes up blurry noises. Both these things happened after the other person repaired the phone. Any suggestions?
Thanks!
Score 1
1 Comment:
I have this problem too. I think it is because the iPhone SE actually uses a different front mic than the iPhone 5S, and the screen kits that are advertised as 5S/SE compatible have only the 5S mic.
by
Add a comment
1 Answer
The camera/mic cable is either improperly seated or damaged. Start here: iPhone SE Front Facing Camera and Sensor Cable Replacement
1 Comment:
Thank you for suggesting, ive tried 3 different of them and the microphone is still not working
by
Add a comment
Add your answer
Iver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 82
