Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 sudden death wont turn on charge or be reconigzed by itunes
Hello I have just changed my screen on iphone 6, the screen replacement went okay I replaced the screen and nothing bad happened, I put the iphone in the charger and then I opened snapchat, I took a picture with blitz and then my iphone died out. I assumed that my battery needed to be replaced so i ordered a battery and replaced it but it still wont turn on. I have tried the hard reset and everything but I just can't get it to turn on.
Please help
Add a comment
1 Answer
Chosen Solution
Well, the failure shortly after a DIY repair could be a coincidence. This could also be caused by the original impact/drop that caused the screen to crack in the first place. It's hard to say from where I'm sitting.
I would go back through this guide and double check my steps to insure I didn't forget anything important. Things to check for are whether or not you installed the correct screws for the LCD bracket. Putting the wrong screws in can cause Long Screw Damage.
I would also try the original, cracked screen to see if that works. If it does, it means your replacement screen is defective. Finally, you could try to connect only the battery and Dock to the logic board and see if Itunes recognizes the device. If it doesn't, then you most likely have a logic board issue and that would have to be looked at by a micro-solderer.
Score 3
1 Comment:
my iphone 6 suddenyl turn out when i locked it and when i turn it on it doesn't work already no screen will feature all black out. I did not charge it, it only connects to wifi, i just chatted my friend and when i locked it then i turned on no screen appear all black out. whats the reason and what would be the best thing to do to revive my iphone 6. pls help:(
by
Add a comment
Add your answer
Momin Yasin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,311
