PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
388 Questions View all
Light bar, one burst of orange then nothing.
Recently I have swapped the analog sticks on my dual shock 4 because they had worn away.
After re-assembling the controller, it won't turn on without being plugged into the PS4 via USB. Once connected the controllers light bar, will pulses orange once and go black.
After this I can then connect the controller to the PS4, but only the X button will work, and the Triangle button will work, but act as the Circle button. None of the other buttons/analog sticks will work on the controller.
I have since re opened the controller, changed the ribbon connecting the light bar to the controller. But after changing this I've still got the same outcome.
I have also tried resetting the controller with the button next to the L2 trigger, but still the same result.
If you guys have any ideas on how to solve this, that be be amazing. Thanks =)
Score 1
Add a comment
Check if the battery is properly connected if not you might have damaged it.
1 Comment:
@harisahmed123 I have checked and the battery is fully connected. Do you recommend a replacement?
by
Add a comment
This might be a solution. It worked for me.
https://youtu.be/GBpqfhPPJPw
1 Comment:
What I did is I got a sharp pin and pressed the little reset button at the back of the remote underneath the L2 button there should be a hold get a pin or anything that can fit inside the hole then hold down for about 4-6 secs do this whilst it is on charge then press the ps button and it should turn blue again
by
Add a comment
Deez mf nutz my sweaty draggy ballz
Add a comment
Add your answer
Stephenpope will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 83
All Time: 27,094
