Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Cellular antenna and iTunes cable sign
The signal of the mobile vanished so I took it to a technician whir tried to replace different antennas but didn’t work when I received the Mobil the iTunes cable sign was appeared and still on that sign with out opening so I took it to another technician who tried to replace it but failed so he told me that the logic board need to be replaced (bearing in mind it didn’t fall or crashed) so what you advise me to do?
1 Comment
on the dial screen type in *#06# if the imei number doesnt show chances are it will need the baseband ic repaired
by
Add a comment
1 Answer
Most Helpful Answer
The technician that first worked on the phone killed it. It should not be stuck on recovery mode just from changing antennas.
Score 1
4 Comments:
So i should replace the logic board or there are any other solutions?
by
did you try a restore on itunes to see if that sorts the itunes screen problem, the 1st tech should have checked to see if it was showing the imei to indicate if it could possibly be the baseband ic, him or the 2nd tech could have caused pry damage somewhere on the board
by
Hmm you are right. Restores can fail due to bad baseband.(-1).
by
Yes that’s what exactly I found when i tried to restore it by iTunes (error -1) is that mean that logic board should be replaced ?
by
Add a comment
Add your answer
Omarashraf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 81
