Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won't power back on after glass-only replacement
A few weeks ago my phone screen broke, and I just replaced it. I was still using the phone, so I know there was no damage to the digitizer or anything on the logic board. Me being cheap, along with not wanting to get an aftermarket LCD that might have bad coloring, I decided I would just replace the glass, especially since I knew there was no damage to the digitizer.
So last night I finished replacing the screen. I took the broken glass off by using a hair dryer on low to melt the glue and then carefully removed the glass. I put on the new glass with LOCA, cured it, and then replaced all of the components. However, when I reconnected everything and tried to power the phone back on, it wouldn't turn back on.
I'm pretty sure it's not just the LCD not working, because I tried turning it on and then using the side switch to turn the vibration on and off. I also checked if it was the battery by making sure it was charged, doing a power cycle, and trying to turn the phone on with the battery unplugged but the charger still connected. I also went back and checked the screws and made sure everything was connected properly.
When trying to charge it, there's no ding to signal it's plugged in. Also, when I connect it to my computer it is recognized by iTunes, but there's a lock on it so I can't do anything. I've left it charging overnight, tried leaving it disconnected from the battery, but it still won't power on. I also don't believe it's a backlight issue because I tried shining a strong flashlight on it but there's no image.
I've already tried this article and all of its recommendations, so please don't direct me to it: http://www.hcqs.us/blog/iphone-wont-turn...
Also, every time I tried reconnecting the cables or doing anything, I disconnected the battery first, including before I started taking it apart the first time. The only thing I can think of that I did wrong was not wearing gloves when I put it back together. When I took it apart I was wearing latex gloves, but when I put it back together I forgot to put them back on, probably because I was excited to have my phone back together. I don't remember feeling any shock or hearing anything, but I was sitting on a fabric couch with my feet on carpet and my phone on a wooden table. This is the only thing I can identify where I might have messed up.
Any ideas? I've heard of micro-soldering to fix something, but I'm hoping to exhaust all options first. I also haven't taken it in to a shop because I'm cheap and I prefer doing things as much as I can myself. Any recommendations would be greatly appreciated.
Score 2
Add a comment
1 Answer
Chosen Solution
First suggestion would be to find another iphone 6 screen to test to eliminate the screen as the issue...or, just take the screen off and take your phone with you to a phone repair and ask if they would mind testing your screen on a test phone...I have several and know most shops would as well.
After testing the screen you repaired and verify it is good...answer back for further troubleshooting steps on no image.
Best to start where you know it was working last and eliminate the obvious before assuming its the logic board (It still could be, but don't want to start going through all the testing when a 2 minute test on the screen should be first step).
Best of luck!
Score 1
Add a comment
Add your answer
Kate Beckner will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 93
