Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
799 Questions View all
What should a nonbroken HDD sound like/ HDD broken or battery?
My iPod's HDD makes some strange clicking sounds, and if I let it rest a day I can't switch it on without restoring it. After that, the screen is frozen but the battery is around 80%.
When I plug it in a powersupply it starts well.
What could it be, HDD or battery? Because I changed the battery a few days ago.
Score -1
2 Comments
Hi,
sorry this is not really an answer, but to give you a better answer, why did you change the battery? Was there only an battery issue or something else too?
by
Well,
the battery was old, and so I swapped it out. Before I did this, I couldn't start the iPod. After the replacement it worked fine but there was the failure I talked about.
I think I'll just try to reset it with iTunes, maybe it's just a fragmented HDD?
by
Add a comment
1 Answer
Chosen Solution
When hard drives fail, they tend to make a rythmatic clicking, though it varies with each drive, it tends to be two clicks, then a pause then two clicks again, somewhat like a heartbeat, though this will vary with each drive.
Score 2
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 1,792
