The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Certain app not being deleted.
I recently downloaded an app for my iPad 2, However it said i did not have enough memory on my iPad and now it wont go away even when i try to delete it.
Help will really be appreciated.
Thanks
2 Comments
Can you clear up enough memory to fully download the app and then delete it?
by
I tried that but it doesnt seem to continue downloading.
by
Add a comment
1 Answer
Chosen Solution
I would try this:
• Connect iPad to Mac or PC
• Launch iTunes
• Create a full backup (do not back up or transfer apps if it asks)
• put the iPad in DFU mode
• install iPad's firmware in DFU mode
• restore from the backup you just made
What this does is clears up a lot garbage files that build up.
It also allows you to manually install apps you want back.
Score 1
3 Comments:
Problem is i have not created a backup.
by
I did mention use iTunes to create a backup. in the 3rd bullet point.
by
It worked omg thanks!
by
Add a comment
Add your answer
Cody Rutherford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 56
