The home base for Android tablets.
Using micro usb for iPhone
Hi,
I'm gonna be getting a android tablet and installing windows onto it.
Can I use the micro usb / USB host to connect an iPhone with? Obviously I'll need an adaptor
4 Comments:
What is your reasoning on interconnecting them?
You do realize iTunes won't run in a VM as it needs direct access to the USB port
by
I don't need iTunes just the ability to run 3uTools
by
Not sure 3uTools will work here either
by
Just googled off the fly.
Thinking I might get a linx tablet and install 3uTools on that.
Really just want a tablet anyway but instead of lugging my laptop around to check people's battery health and other tools on 3uTools I thought a tablet would be enough
by
Add a comment
1 Answer
Curious, what Android tablet allows Windows installation? I've not yet seen one with an Atom processor that is supported by Windows 10.
If you mean to use a standard MicroUSB cable to sync/charge an iPhone, yes. Here is the lightning adapter.
https://www.amazon.com/SMALLElectric-Cer...
2 Comments:
by
Oh I see what you are trying to do.
So for a second requirement, you need to either find a tablet with a full sized USB "A" side female port or a tablet with the hub that supports an additional Micro "B" male to "A" female adapter.
by
Add a comment
Add your answer
Jaymie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 80
