Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
Why doesn't my external hard drive connect to the Mac
My external Hard Drive used to work perfectly, then out of nowhere the computer wont recognize any Drive, I even connected it to another computer and nothing. The disk still spins though.
Add a comment
1 Answer
Most Helpful Answer
Reconnect it to your Mac then launch Disk Utility does the drive show up under it? If it does run Disk First-Aid to see if it can fix the corruption.
If you can't see the drive with Disk Utility or it can't fix it the drive has gone bad. Hopefully you have a backup, if not you might be able to get a data recovery service to recover your stuff but it's expensive!
Score 1
Add a comment
Add your answer
Marcelo Marquez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 935
