Repair guides and disassembly information for laptops manufactured by ASUS.
2525 Questions View all
Keyboard displays numbers instead of letters
My daughter and I are switching laptops while she is in school. It's old and came with Windows 8 but now has Windows 10. We recently took it to our local Windows store to have her stuff taken off her ASUS so I would start fresh. Now when I try putting in my password, some keys display numbers instead of the letter. The "O" also has the number 6 on it and that 's what shows up. I thought maybe I had the caps on but no. Any ideas?
Score 4
Add a comment
Chosen Solution
You need to turn off Number Lock on the keyboard.
To do this, at the top you will see a key marked "Num LK".
If simply pressing this doesn't turn off the number lock, locate the "FN" key, hold the "FN" key down, then press the "Num LK" key.
Score 10
7 Comments:
Thanks, you save my day!!
by
I am so grateful for the information, thank you!
by
thank you sooooooo much.........you can't understand how worried i was about this problem ....... thank u very much for this solution........
by
Thanks a lot, I was so worried. You just helped a lot
by
Mine does not have a numlock button on it
by
Show 2 more comments
Add a comment
Hi @bfloabbott, i think you had trigger the num lock on your laptop keyboard, or due to external keyboard num lock.
just turn it off and it should be good to go :)
Score 3
1 Comment:
Bruh, thank you. I knew I had a numlock problem but it didn't occur to me that it was because I was using an external keyboard. Thanks so much.
by
Add a comment
On my asus laptop the numbers on the right side will not work on the tesco website. Ive tried so many things but still cannot resolve. I was goi g to send for repair but as they work on most sights than dont want to end up getting charged for it.
Can anyone advise me please?
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 103
All Time: 38,089
