Repair manuals and support for 4-wheeled passenger and cargo vehicles.
How to clear a clogged catalytic converter
My secondary catalytic converter is clogged coming from the exhaust manifold down past the first catalytic converter into the second one I've removed it tried to spray brake fluid in it any advice
Score 1
4 Comments
Sorry, what make and model Samsung do you have? I am not familiar with any Samsungs with Catalytic convertors and exhaust manifolds.
by
What is the make, model and year of your car?
by
We have a 2008 2lt x-type jag which may have a cat problem. Code is showing up for it.
by
So when i put the cat clleaner in it will clean it the only code coming up is cat converter needs to be
by
Add a comment
Chosen Solution
Clogged catalytic converters typically aren't cleaned, they're replaced. Once a cat gets clogged the exhaust is able to superheat the catalysts inside, melting/fusing them together and creating a more significant blockage. There is no saving it; it must be replaced.
Ghetto "workarounds" -- none of which are recommended -- include removing the O2 sensor in front of the cat (will cause performance and emissions issues, also illegal), banging hard on the cat with a hammer to break it up and then starting the car to blow out the broken pieces (more performance and emissions issues, also illegal), removing the cat and soaking it for a day in either a heavy concentration of Dawn dish detergent and vinegar, acetone, or sodium hydroxide -- none of which are really effective and sodium hydroxide is pretty nasty as well.
Here's a reasonably good video about "cleaning" a catalytic converter: https://www.youtube.com/watch?v=L_QIRFUg...
Score 7
4 Comments:
@secondlife great explanations on cleaning the CATalytic convertors. For an lamen like me, I had to read a few times before I realized you shortened catalytic convertor to simply "cat". I had some colorful visions of a feline, a plunger, and tail pipe, along with comedian Gallagher and a feline. Both of which would have PETA on your tail (no pun intended).
by
Let's be frank about.
Cleaning a CAT "can and will work... Especially, if you're honeycomb does "not" have a hole in it!
The video is BS, exactly for that reason!
Not one person cares about readings if their car runs great and there's no DTC codes (Passes smog)!
Please stop co-signing for CAT makers to rip us off most of the time!!!
Cleaning CATs works.... Provided the honey comb is intact (can't hold pressure without).
FACT!!!
by
@secondlife the image in my head of your comment was way too funny... thanks for the humor, I needed that!!
by
Someone is a ward clever square.. you better use a crosswalk sir or that's illegal
by
Add a comment
Bought a 1975 Olds Omega yrs ago for my son's first car to kick around in while learning to drive. Old couple owned it since new, both in their 80's. No longer could drive due to health.
Floored down the highway, kept dropping tranny down to build RPMs building exhaust pressure to blow it out & to hit 25mph finally after 30-40 mins in it...lol Next day I unbolted the converter, soaked it in dish soap, that failed, so did kerosene, acetone, brake cleaner anything we could pour in it. This done very little but made it legal on a highway if you dare. It was so clogged it took forever to reach 55mph but it would finally reach it. Finally I ripped the cat off again, filled it with karosene & lit that bad boy up (3-4 times). Slapped it back on and ran that car to death over a week or two & it ran good afterwards. It's converter had the deflection plates inside. Not like todays converters you can gut if you choose so they were very problematic to say the least back then.
I only saw 2 converters get this bad (well worse). A 1986 Firebird a freind putted around in so much at 51k miles 2 mechanics told her the trans failed cause it couldn't move from the spot the wrecker dropped it off in her back yard. I went & looked at it (car sat there 2 months) and I noticed it rocking both backward/forward just a ticks turd but engine bogged down bigtime when she floored it. Put my hand at the tailpipe & I felt nothing. Notta! Asked her for a hammer, after she laughed then freaked out realizing I was seriously going to hit her precious ride with it trying to repair it, you know that look?
So I crawled under it & just beat the hell out of her cat.
Got up, said start it & drive it!
Car took right off, she was shocked!
So first I called dealer because warranty in cats then ran out at 50k, she had 1k over & they said tough chit lady. I tried anyway!
No doubt it was clogged real bad before 50k. Over $300 for cat alone everywhere we called but one shop said, $118 installed, around 1990? We babied it there so we didn't clog the muffler that cost way more than her cat, big one! When she left the shop, the car went sideways out their lot, she was so used to flooring it everywhere just so it moved & she nearly lost it. She said it was a brand new car again! Shocked she didnt notice it but I told her it does it over & time not suddenly. People never notice all their powers gone!
My other freind had a 1978 Buick Riviera that burnt to the ground after returning home from a long trip. Floorboard heated so bad the carpet ignited & his weenie roast began. Luckily he climbed out cause he certainly would have had one...lol
So for all those who put non-foulers on your O2 sensors to stop bad cat codes/light, think about that a minute?
If you still decide to heres a decent plan of action?
1) Gotta call & get your full coverage goin.
2)stock up on hot dogs & marshmallows to have quickly.
3) Stop buying brand new tires for it, wasting hot dog money.
4) Keep your cell phone/wallet/Ins info in your pocket at all times, never in its console.
5) Write all your buds/family's numbers down to invite to the weenie roast, that's so you'll have a ride home too. My buddy Bob got lucky his was at home. No hot dogs, man what a waste of a big fire.
6) Don't forget sticks or those fancy extending weenie/ marshmallow holders.
7) Oh' & the beer don't forget the beer, nobody will come with no beer so you'll be walking home then for sure. Probably should practice saving the beer from the fire too.
Idk, seeing this I think its less trouble just changing cat out myself.
Score 1
2 Comments:
I’ve not laughed so hard from a post in quite awhile. This my friend is hilarious and so true. I’m beat a cat as we speak.
by
Of someone can point me in the direction to get a new cat for my 03 ram 15005.7 v8 hemi that would be great, every web site says it off stock or unavailable. So until I find one the non fouled is stayingor someone can buy me a new fn truck
by
Add a comment
I recently used cataclean to get my car through a failed MOT on bad emissions. After burning that tank of fuel I got the car retested and it was a lot better. I only paid £15 or so for the cleaner also - https://www.motorverso.com/catalytic-con...
2 Comments:
How often can you continue to use Cataclean? I've used it once 3 months ago and my check engine light reappeard.
by
Does anybody know the answer
by
Add a comment
Hi there, why my comments keep disappearing? I only wanted to help.
3 Comments:
The robot scanner checks new posts and automatically deletes ones that look too much like spam. I checked your deleted posts and yes, they do indeed closely resemble spam; that is, commercial advertisements that are only tangentially related to the original post.
That's why your posts are getting deleted; you can appeal to iFixit personnel, but given what I saw I suspect you won't get far with that.
by
@genevamcdonald looks like SPAM to iRobot and the mods on here :-) You got any other non-spam comment /answer you could provide in regards to a clogged catalytic converter?
by
That's to funny, I'm a real human being with a honest to goodness question and your response is I must be a SPAM ? I'll never ask this site ever again for much needed help on my Catalyst problems.
by
Add a comment
Add your answer
Lonny javille will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 136
Past 30 Days: 845
All Time: 151,195
