MBP not powering on
Hi,
I was hoping you could give me some advice?
I did something very very stupid to my MacBook Pro 2011. My gfx card on the original logic board had decided to no longer work, later found this was a design fault, anyway ask I work this computers I felt confident enough to take on the take of replacing the logic board myself. I changed the logic board and powered up the MBP. The logic board I had purchased was working and I was very happy, for about a week, then it wend back to the same problem.
Not wanting to have to do this process on a weekly basis, I did some research and found that others who had the same issue said you can upgrade the logic board to a mid 2012 logic board.
After scouting the internet for more information and gathered enough information to upgrade the logic board. I went ahead and ordered the board. all excited on its arrival I went to fit the board with all the little bits than go with it.
I booted the MBP and it works and I was ecstatically happy! So while the laptop was booting up I was impatient to wait for the laptop to finish booting to then power it down. I had the little metal guard left to screw in, only dropped the screw on the logic board and sparks came out and everything went dead. (I know, I'm not feeling proud at the moment) I tried to revive the laptop with no success and came to the conclusion that I have fried the logic board.
So I ended up buying another 2012 logic board (arrived today) I have very carefully swapped out the logic boards (made no errors this time) and went to turn on the MBP and noting not response, so I plugged in the MagSafe power adapter, the little green light comes on, I go to power the MBP and still not sign of life. I disconnected the power and then removed the battery, reconnected it and plugged in the MagSafe cable back in, the green light comes on but again I have no response. I pressed the battery indicator on the side and that isn't responding either.
Is it possible that the battery could be fried or the logic board is faulty?
I bought the logic board for this site and it has the QA sticker on it.
I would be grateful for any trouble shooting ideas
Thanks
Embarrassed Munro
Update (09/13/2017)
Hi,
Thanks for responding. I have included a photo of my logic board
With in the red square is roughly where I dropped the screw.
But also my new logic board isn't working either.
thanks
Munro
6 Comments
Well your board is not necessarily fried. They are very fixable. Send me a pic of where the screw fell so I can determine where the voltage went.
by TCRS Circuit
Hi
I have put a photo in the original feed. I couldn't figure out how to paste one in here.
Thanks
Munro
by munrocullum
Just had a thought, could it be the battery thats been damaged?
by munrocullum
Could be. Post a pic of where the screw fell.
by TCRS Circuit
I have added the photo in at the bottom of the original feed.
Thanks
by munrocullum
Show 1 more comment
