Inconsistent Brewing on K70
I am trying to fix a K70. It will usually brew a cup once or twice, then stop brewing. Once it stops, it will make little to no noise and not pull water in. I've ruled out the one way check valve on the top. I also followed the steps to lube the vacuum pump diaphragm. If I unplug the Keurig, it seems to reset and will brew another cup once I plug it in. Any thoughts on what to try next? It seems like it could be a pump problem, but I'm not sure.
Add a comment
1 Answer
Most Helpful Answer
@bbh try to hold down the on/off button and plug it in. That might reset your Keurig. You may have to try this more than once. It should brew a cup followed by another etc.
Score 1
Add a comment
Add your answer
Brandon Hanisch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 188
