4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
iPhone SE turning itself off on lock screen?
Phone was dropped down the toilet. I tried to fix it using the isopropyl alcohol method. All seemed fine, but then the phone turns itself off when it's on the lock screen every time.
What's happening here? Is it the battery? (As it was replaced due to me ruining the original when I tried to remove it) is it the screen itself??
Also, which areas do I need to check to try and figure out what's happened.
Add a comment
I think the power switch is short circuiting, causing the screen to cycle on and off.
Add a comment
could be also a battery issue.
Add a comment
Add your answer
Kim will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 252
