Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Battery no voltage at flex contacts, but voltage at battery terminals
Hi guys, I have an iPhone 6 plus battery that isn't charging. It has been sitting discharged a long time. I'm trying to manually bring up the voltage a bit so the iPhone will accept it and charge it.
The very tiny battery connector contacts at the end of the battery's flex cable show no voltage with multimeter.
I peeled back the top of the battery to measure directly from the cathode and anode terminals, bypassing the flex cable and its circuitry, and that does show voltage.
These pictures show the area.
I noticed that the positive contact on the flex connector seems to show the correct voltage if the negative probe of the multimeter is placed directly on the battery's negative, rather than on the flex negative. Placing both probes on the positive and negative flex contacts shows no voltage. It would seem the battery itself is fine, but the negative contact on the connector at the end of the flex cable is broken, while the positive contact on the connector seems ok. Unless something else is going on?
Is there any way to fix this, or other ideas? I am trying to salvage the battery. Any help is appreciated.
Add a comment
1 Answer
Chosen Solution
I would suspect that the gas gauge circuit is damaged, which would probably explain why the battery stopped taking a charge prior to letting it sit in drawer. If you have access to some form of magnification, do a thorough visual inspection. With any luck, you may notice something that is repairable. If you really want to salvage this battery (versus landfill), then consider swapping out the control board from another dead or damaged battery that is unrecoverable.
Score 1
Add a comment
Add your answer
rcm88 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 2,871
