Bosch Heat Pump dryer WTW87565AU Error Code F:06
Hi, I have error F:06 on the Bosch heat pump dryer WTW87565AU. Does anyone have the service manual for it? I have service manual for the non heat pump version WTV76100US which is very similar, but the error seems to be for the air circuit which is different in this model. There doesn't seem to be a thermostat for starters, but a temperature probe connected to the compressor. I'm not sure what to check to resolve the error code.
1 Comment
Ok separated out the control board and checked each connection, they all seem to be properly connected. Used multimeter to check continuity, all connections seem fine.
So looking for thermostats, found 2 - there is presumably a NTC above the front of the tumbler, resistance 176 ohms slowing rising if connected to 9V multimeter. There is another thermostat on the coolant pipe near the compressor, reads 8940 ohms. I think it is for the temperature of the returning coolant from the cooling circuit.
Checked the door switch too, circuit open if door open, circuit closed if door closed.
by Tim Geoy
