The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
Water damaged phone , it works but the screen is black then be pink
My mobile came on it some water i dryed it with a towel then it was working fine the screen was flickering , i put it in the charger then slept , when i get up the screen was whit and the phone turns off and didn't turn on again i putted in rice for a day and half and used the vaccum it worked and the touch works but the screen is black and after 5 seconds it turns to pink slowely , how to fix that problem ?
Add a comment
1 Answer
Most Helpful Answer
@hazemm3 okay first off let me state the obvious "Rice does not work" It does not do anything." It does not prevent corrosion nor does it fix your phone.
The very first thing you want to do is to not try to restart the phone. This may further damage your phone. you also do not want to try to charge it any further. The next thing to do is to clean it. Disassemble your phone using these guides Once it is disassembled, you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for an Apple iPhone3G all the points are still pertinent to your phone. Do not forget to remove the EMI shields for proper cleaning. While you are cleaning it, check for any broken, missing or burned looking components. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. It is possible that your damage is contained to the display but may be related to the board as well. Unless you clean it properly there is no sure way to diagnose this.
Score 1
Add a comment
Add your answer
hazem will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,115
