Repair guides and support for 27" Intel iMacs by Apple, introduced October 2009.
3403 Questions View all
Why is not powering though there is just one led light on the board.
My iMac 27 is not powering, I opened it and discovered that there is one led light on when connected to power outlet but other three led are not, I checked around the board to me everything is intact but can't figure out why is not powering when I press the power button. Please what next should I do to rectify this issue.
Score 1
Add a comment
1 Answer
Chosen Solution
All the #1 LED indicates is that there is trickle power getting to the power supply. This does not means the power supply is working. I'm 98% sure you will need to replace it. But to get you to the correct part and guide I need to know your exact machine. There are two numbers on the bottom of the stand used to identify. One is an EMC number the other a model number and looks like: Axxx
If you can give us those numbers we can get you tot the part and guide.
Score 1
Add a comment
Add your answer
Engr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 40
